当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Place the phone on a flat surface with the front facing down.
Insert your finger under the gray plastic cover at the bottom end of the phone.
Lift the cover off the phone.
Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
If the antenna is not fully extended, the top left screw will not be accessible.
Gently lift the end of the circuit board farthest from the phone hinge.
The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
Grasp the keypad at the bottom of the phone, raise it, and pull it away.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
