跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The headphone port allows the user to redirect the speaker output to a pair of headphones when the headphones are plugged into the port.
  1. Place the phone on a flat surface with the front facing down. Insert your finger under the gray plastic cover at the bottom end of the phone. Lift the cover off the phone.
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Place your thumb in the notch in the lower left corner of the battery compartment. Lift the battery up and away from the phone. Remove the battery.
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Locate the metal slider that holds the SIM card in place. Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Lift the metal flap to gain access to the bottom of the SIM card. Remove the SIM card by sliding it out parallel to the bottom of the flap. Remove the SIM card by sliding it out parallel to the bottom of the flap.
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  6. Extend the antenna.
    • Extend the antenna.
  7. Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  8. Gently lift off the back half of the phone and set to the side. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  9. Locate the headphone port at the bottom right corner of the circuit board.
    • Locate the headphone port at the bottom right corner of the circuit board.
    • The headphone port cannot be removed from the phone. If cleaning the port does not fix the problem, the entire phone must be replaced.
结论
Garrison Stevens
于2012年10月22日注册
1 信誉积分
创作了6篇指南
团队
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G2
4 名成员
创作了16篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 325
