跳转到主内容
Motorola i450 Boost Mobile Circuit Board Replacement
你所需要的
  1. Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: 步骤 1 中的图像 1,3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: 步骤 1 中的图像 2,3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Circuit Board Replacement, Battery: 步骤 2 中的图像 1,3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: 步骤 2 中的图像 2,3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: 步骤 2 中的图像 3,3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: 步骤 3 中的图像 1,2 Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: 步骤 3 中的图像 2,2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Circuit Board Replacement: 步骤 4 中的图像 1,3 Motorola i450 Boost Mobile Circuit Board Replacement: 步骤 4 中的图像 2,3 Motorola i450 Boost Mobile Circuit Board Replacement: 步骤 4 中的图像 3,3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 1,1
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Circuit Board Replacement: 步骤 7 中的图像 1,3 Motorola i450 Boost Mobile Circuit Board Replacement: 步骤 7 中的图像 2,3 Motorola i450 Boost Mobile Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
结论
Amber King
于10/22/12注册
8 声望
创作了2篇指南
团队
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G2
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 419
