跳转到主内容
Motorola i450 Boost Mobile Antenna Replacement
你所需要的
  1. Motorola i450 Boost Mobile Antenna Replacement, Antenna: 步骤 1 中的图像 1,3 Motorola i450 Boost Mobile Antenna Replacement, Antenna: 步骤 1 中的图像 2,3 Motorola i450 Boost Mobile Antenna Replacement, Antenna: 步骤 1 中的图像 3,3
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. Motorola i450 Boost Mobile Antenna Replacement: 步骤 2 中的图像 1,3 Motorola i450 Boost Mobile Antenna Replacement: 步骤 2 中的图像 2,3 Motorola i450 Boost Mobile Antenna Replacement: 步骤 2 中的图像 3,3
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
结论
Garrison Stevens
于10/22/12注册
1 声望
创作了6篇指南
团队
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G2
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 391
