跳转到主内容
Motorola i1000plus Motherboard Replacement
你所需要的
  1. Motorola i1000plus Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Motorola i1000plus Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Motorola i1000plus Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Motherboard Replacement, Antenna: 步骤 2 中的图像 1,3 Motorola i1000plus Motherboard Replacement, Antenna: 步骤 2 中的图像 2,3 Motorola i1000plus Motherboard Replacement, Antenna: 步骤 2 中的图像 3,3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Motherboard Replacement, Back Cover: 步骤 3 中的图像 1,3 Motorola i1000plus Motherboard Replacement, Back Cover: 步骤 3 中的图像 2,3 Motorola i1000plus Motherboard Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Motherboard Replacement: 步骤 6 中的图像 1,3 Motorola i1000plus Motherboard Replacement: 步骤 6 中的图像 2,3 Motorola i1000plus Motherboard Replacement: 步骤 6 中的图像 3,3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
  7. Motorola i1000plus Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
  8. Motorola i1000plus Motherboard Replacement: 步骤 8 中的图像 1,3 Motorola i1000plus Motherboard Replacement: 步骤 8 中的图像 2,3 Motorola i1000plus Motherboard Replacement: 步骤 8 中的图像 3,3
    • Using a pair of tweezers, firmly grasp the connector at the top of the phone and pull the connector straight away from the phone.
    • Do not pull the connector off by the wire. This could damage or destroy the wire or connector.
  9. Motorola i1000plus Motherboard Replacement: 步骤 9 中的图像 1,2 Motorola i1000plus Motherboard Replacement: 步骤 9 中的图像 2,2
    • Unclip the ribbon cable, located underneath the motherboard, by using the spudger to push up on the dark brown part of the connector located on the circuit board.
    • Do not pull the motherboard too far away from the phone with the ribbon cable still connected. this will damage the cable or the motherboard.
  10. Motorola i1000plus Motherboard Replacement: 步骤 10 中的图像 1,2 Motorola i1000plus Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the motherboard by firmly grasping the edges of the circuit board with one hand and the phone with the other and pulling up on the motherboard slightly and then pulling it straight down toward the bottom of the phone.
    • Be sure to pull straight down to disconnect the ribbon cable properly. Pulling in another direction may cause damage to the cable or the motherboard.
结论
Matthew Byrd
于10/18/13注册
401 声望
创作了4篇指南
团队
Clemson, Team 13-3, Benson Fall 2013 Clemson, Team 13-3, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G3
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 159
