跳转到主内容
Motorola i1000plus Back Cover Replacement
你所需要的
  1. Motorola i1000plus Back Cover Replacement, Battery: 步骤 1 中的图像 1,3 Motorola i1000plus Back Cover Replacement, Battery: 步骤 1 中的图像 2,3 Motorola i1000plus Back Cover Replacement, Battery: 步骤 1 中的图像 3,3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: 步骤 2 中的图像 1,3 Motorola i1000plus Back Cover Replacement, Antenna: 步骤 2 中的图像 2,3 Motorola i1000plus Back Cover Replacement, Antenna: 步骤 2 中的图像 3,3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,3 Motorola i1000plus Back Cover Replacement, Back Cover: 步骤 3 中的图像 2,3 Motorola i1000plus Back Cover Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: 步骤 5 中的图像 1,1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: 步骤 6 中的图像 1,3 Motorola i1000plus Back Cover Replacement: 步骤 6 中的图像 2,3 Motorola i1000plus Back Cover Replacement: 步骤 6 中的图像 3,3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
结论
Austin Lake
于10/18/13注册
501 声望
创作了5篇指南
团队
Clemson, Team 13-3, Benson Fall 2013 Clemson, Team 13-3, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G3
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 200
