跳转到主内容
Motorola g stylus battery Replacement
你所需要的
  1. Motorola g stylus battery Replacement, remove  the sims card and tray: 步骤 1 中的图像 1,2 Motorola g stylus battery Replacement, remove  the sims card and tray: 步骤 1 中的图像 2,2
    • Use your sim card eject tool to remove the sim card and tray.
  2. Motorola g stylus battery Replacement, remove stylus: 步骤 2 中的图像 1,1
    • Remove your stylus pen from the phone.
  3. Motorola g stylus battery Replacement, removing the back of your phone: 步骤 3 中的图像 1,3 Motorola g stylus battery Replacement, removing the back of your phone: 步骤 3 中的图像 2,3 Motorola g stylus battery Replacement, removing the back of your phone: 步骤 3 中的图像 3,3
    • Using your heat gun or a hairdryer heat the back of the phone to loosen up the adhesive.
    • Now using your opening devices go along the edge of the phone slow and easy prying along the edges till they're loose.
    • As you're lifting up the back of your phone be sure you watch out for the fingerprint scanner, just keep it pushed down while you're lifting up the back of the phone .
  4. Motorola g stylus battery Replacement, top and botttom inside covers: 步骤 4 中的图像 1,2 Motorola g stylus battery Replacement, top and botttom inside covers: 步骤 4 中的图像 2,2
    • Here you will have 15 t4 screws on top and bottom to take out but be careful with the top cover because the finger sensor runs under it. You don't want to rip that
  5. Motorola g stylus battery Replacement, Removing the battery: 步骤 5 中的图像 1,1
    • Here we need to be careful that we don't damage the battery, so unhook the battery and its flex cable. Then carefully get one corner of the battery lifted up to where you can get a good grip to pull on it. You will have to pull it slower so you don't damage the battery once that is done you made it.
    • New line.
结论
5等其他人完成本指南。
Trent Weaver
于09/16/20注册
232 声望
撰写一个指南
一条评论
Yessir, you the man bro
0% 100% - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 101
总计 7,515
