跳转到主内容
Motorola Xoom Wifi Earphone Port Replacement
你所需要的
  1. Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: 步骤 1 中的图像 1,2 Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: 步骤 1 中的图像 2,2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Earphone Port Replacement: 步骤 2 中的图像 1,2 Motorola Xoom Wifi Earphone Port Replacement: 步骤 2 中的图像 2,2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Earphone Port Replacement: 步骤 3 中的图像 1,3 Motorola Xoom Wifi Earphone Port Replacement: 步骤 3 中的图像 2,3 Motorola Xoom Wifi Earphone Port Replacement: 步骤 3 中的图像 3,3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: 步骤 4 中的图像 1,3 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: 步骤 4 中的图像 2,3 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: 步骤 4 中的图像 3,3
    • Remove one screw with a T-5 bit.
    • Lift the black casing off of the ports.
    • Remove earphone port from the motherboard.
结论
另外一个人完成了本指南。
William Prins
于04/14/14注册
604 声望
创作了3篇指南
团队
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G39
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 284
