简介
Common problems with the Xoom 2 is a gradually forming looseness in the charging port assembly or even a bent or broken charging port. Follow this guide to replace or fix your charging port assembly.
Note: We will be using a Torx T5 screwdriver for all of the steps in this guide.
你所需要的
Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
Using tweezers, gently pry up the piece of yellow Kapton tape that is holding several cables in place.
即将完成!
结论
