跳转到主内容
Motorola XOOM 2 Media Edition Back Facing Camera Replacement
你所需要的
  1. Motorola XOOM 2 Media Edition Back Facing Camera Replacement, Motorola XOOM 2 Media Edition Disassembly: 步骤 1 中的图像 1,2 Motorola XOOM 2 Media Edition Back Facing Camera Replacement, Motorola XOOM 2 Media Edition Disassembly: 步骤 1 中的图像 2,2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Back Facing Camera Replacement: 步骤 2 中的图像 1,2 Motorola XOOM 2 Media Edition Back Facing Camera Replacement: 步骤 2 中的图像 2,2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Back Facing Camera Replacement: 步骤 3 中的图像 1,3 Motorola XOOM 2 Media Edition Back Facing Camera Replacement: 步骤 3 中的图像 2,3 Motorola XOOM 2 Media Edition Back Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Back Facing Camera Replacement, Back Facing Camera: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently remove the blue tape near the camera using the tweezers.
  5. Motorola XOOM 2 Media Edition Back Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Using the tweezers, remove the camera by grabbing the metal and pulling it out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 417
