跳转到主内容
Motorola W490 Lower Metal Frame Replacement
你所需要的
  1. Motorola W490 Lower Metal Frame Replacement, Phone Casing: 步骤 1 中的图像 1,2 Motorola W490 Lower Metal Frame Replacement, Phone Casing: 步骤 1 中的图像 2,2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 Lower Metal Frame Replacement, Battery: 步骤 2 中的图像 1,2 Motorola W490 Lower Metal Frame Replacement, Battery: 步骤 2 中的图像 2,2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 Lower Metal Frame Replacement, Lower Metal Frame: 步骤 3 中的图像 1,2 Motorola W490 Lower Metal Frame Replacement, Lower Metal Frame: 步骤 3 中的图像 2,2
    • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
    • Remove all the screws using the Torx T6 Screwdriver.
  4. Motorola W490 Lower Metal Frame Replacement: 步骤 4 中的图像 1,3 Motorola W490 Lower Metal Frame Replacement: 步骤 4 中的图像 2,3 Motorola W490 Lower Metal Frame Replacement: 步骤 4 中的图像 3,3
    • Turn over the phone to the front side and open up the phone, displaying the keypad.
    • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
    • Pull and set the glued plastic cover aside.
    • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
  5. Motorola W490 Lower Metal Frame Replacement: 步骤 5 中的图像 1,2 Motorola W490 Lower Metal Frame Replacement: 步骤 5 中的图像 2,2
    • Under the plastic cover, locate two star-shaped T5 screws.
    • Use the Torx T5 Screwdriver to remove the two screws.
  6. Motorola W490 Lower Metal Frame Replacement: 步骤 6 中的图像 1,3 Motorola W490 Lower Metal Frame Replacement: 步骤 6 中的图像 2,3 Motorola W490 Lower Metal Frame Replacement: 步骤 6 中的图像 3,3
    • Turn over the phone to the back side of phone where the battery was removed.
    • Use hands to remove the unscrewed rear frame of the phone.
    • Set aside the rear metal frame.
结论
另外一个人完成了本指南。
Will Edwards
于10/22/12注册
61 声望
创作了9篇指南
团队
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G1
4 名成员
创作了23篇指南
一条评论
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 424
