跳转到主内容
加入维修社区 - 创建账户
Motorola W385 speaker replacement
你所需要的
  1. Motorola W385 speaker replacement, Battery: 步骤 1 中的图像 1,1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 speaker replacement: 步骤 2 中的图像 1,1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 speaker replacement, Front Casing: 步骤 3 中的图像 1,1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 speaker replacement: 步骤 4 中的图像 1,1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 speaker replacement: 步骤 5 中的图像 1,2 Motorola W385 speaker replacement: 步骤 5 中的图像 2,2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 speaker replacement: 步骤 6 中的图像 1,1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 speaker replacement, Top Logic Board: 步骤 7 中的图像 1,1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 speaker replacement: 步骤 8 中的图像 1,3 Motorola W385 speaker replacement: 步骤 8 中的图像 2,3 Motorola W385 speaker replacement: 步骤 8 中的图像 3,3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 speaker replacement: 步骤 9 中的图像 1,3 Motorola W385 speaker replacement: 步骤 9 中的图像 2,3 Motorola W385 speaker replacement: 步骤 9 中的图像 3,3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
  10. Motorola W385 speaker replacement, Main Speaker: 步骤 10 中的图像 1,1
    • Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
  11. Motorola W385 speaker replacement: 步骤 11 中的图像 1,2 Motorola W385 speaker replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Place the spudger between the speaker and the clip shown.
    • Separate the clip from the speaker while lifting on the speaker.
    • The speaker should separate. Use the tweezers to grab the speaker.
结论
另外一个人完成了本指南。
Koedy Brant
于01/26/10注册
41 声望
创作了2篇指南
团队
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G50
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 3,281
