跳转到主内容
Motorola W385 Logic Board Replacement
你所需要的
  1. Motorola W385 Logic Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Logic Board Replacement, Bottom Casing: 步骤 3 中的图像 1,1
    • Hold the phone as shown in the photo.
  4. Motorola W385 Logic Board Replacement: 步骤 4 中的图像 1,2 Motorola W385 Logic Board Replacement: 步骤 4 中的图像 2,2
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
  5. Motorola W385 Logic Board Replacement: 步骤 5 中的图像 1,1
    • Remove the two Torx-6 screws under the removed plastic.
  6. Motorola W385 Logic Board Replacement: 步骤 6 中的图像 1,1
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
  7. Motorola W385 Logic Board Replacement: 步骤 7 中的图像 1,3 Motorola W385 Logic Board Replacement: 步骤 7 中的图像 2,3 Motorola W385 Logic Board Replacement: 步骤 7 中的图像 3,3
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
  8. Motorola W385 Logic Board Replacement: 步骤 8 中的图像 1,1
    • The casing can be easily removed exposing the bottom logic board.
  9. Motorola W385 Logic Board Replacement, Main Logic Board: 步骤 9 中的图像 1,2 Motorola W385 Logic Board Replacement, Main Logic Board: 步骤 9 中的图像 2,2
    • Use spudger to gently separate the ribbon cable from the logic board.
  10. Motorola W385 Logic Board Replacement: 步骤 10 中的图像 1,2 Motorola W385 Logic Board Replacement: 步骤 10 中的图像 2,2
    • Place the sharp end of the spudger in the hole at the bottom of the logic board.
    • Gently remove the logic board from the phone casing.
    • Make sure not to damage any other components of the logic board.
结论
2等其他人完成本指南。
Javier Mendez
于01/21/10注册
13 声望
创作了2篇指南
团队
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G50
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,212
