跳转到主内容
加入维修社区 - 创建账户
Motorola W385 Front Casing Replacement
你所需要的
  1. Motorola W385 Front Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Front Casing Replacement: 步骤 2 中的图像 1,1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Front Casing Replacement, Front Casing: 步骤 3 中的图像 1,1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Front Casing Replacement: 步骤 4 中的图像 1,1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Front Casing Replacement: 步骤 5 中的图像 1,2 Motorola W385 Front Casing Replacement: 步骤 5 中的图像 2,2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Front Casing Replacement: 步骤 6 中的图像 1,1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
结论
另外一个人完成了本指南。
Austin Hobbs
于01/21/10注册
69 声望
创作了3篇指南
团队
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G50
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 26
总计 2,087
