跳转到主内容
Motorola W315 Screen Replacement
你所需要的
  1. Motorola W315 Screen Replacement, Display Cover: 步骤 1 中的图像 1,3 Motorola W315 Screen Replacement, Display Cover: 步骤 1 中的图像 2,3 Motorola W315 Screen Replacement, Display Cover: 步骤 1 中的图像 3,3
    • Insert the spudger between the silver body of the phone and the black "Verizon" display sticker.
    • Work the spudger around the extremity of the sticker.
    • Remove display sticker.
    • Be aware that if the display sticker comes back in contact with the phone it will adhere back to the phone.
  2. Motorola W315 Screen Replacement, Screen: 步骤 2 中的图像 1,1
    • Using the T6 tool, remove the four 5mm screws on the face of the display (circled in red).Before replacing the screen, the four screws beneath the display must already be removed.
  3. Motorola W315 Screen Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Insert the tweezers between the front and back panels of the top half of the device. Make as large a gap as possible using the tweezers.
  4. Motorola W315 Screen Replacement: 步骤 4 中的图像 1,3 Motorola W315 Screen Replacement: 步骤 4 中的图像 2,3 Motorola W315 Screen Replacement: 步骤 4 中的图像 3,3
    • Using the Pry Bar, move around the entire edge of the the device until the two panels separate from each other.
    • Grab the plastic casing and remove
  5. Motorola W315 Screen Replacement: 步骤 5 中的图像 1,3 Motorola W315 Screen Replacement: 步骤 5 中的图像 2,3 Motorola W315 Screen Replacement: 步骤 5 中的图像 3,3
    • Use the pry bar to lift the metal cover from the screen housing.
  6. Motorola W315 Screen Replacement: 步骤 6 中的图像 1,2 Motorola W315 Screen Replacement: 步骤 6 中的图像 2,2
    • Pry the chip connected by magnetic strip from the back of the screen.
    • Remove display circuit board from the body of the phone.
  7. Motorola W315 Screen Replacement: 步骤 7 中的图像 1,2 Motorola W315 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the screen from the front panel of the device.
结论
Justin Scott
于03/26/14注册
501 声望
创作了5篇指南
团队
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G3
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 193
