跳转到主内容
Motorola W315 Keypad Replacement
你所需要的
  1. Motorola W315 Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Keypad Replacement: 步骤 3 中的图像 1,1
    • Insert the new battery.
  3. Motorola W315 Keypad Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Keypad Replacement: 步骤 5 中的图像 1,3 Motorola W315 Keypad Replacement: 步骤 5 中的图像 2,3 Motorola W315 Keypad Replacement: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Keypad Replacement, Circuit Board: 步骤 6 中的图像 1,3 Motorola W315 Keypad Replacement, Circuit Board: 步骤 6 中的图像 2,3 Motorola W315 Keypad Replacement, Circuit Board: 步骤 6 中的图像 3,3
    • Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
  6. Motorola W315 Keypad Replacement: 步骤 7 中的图像 1,3 Motorola W315 Keypad Replacement: 步骤 7 中的图像 2,3 Motorola W315 Keypad Replacement: 步骤 7 中的图像 3,3
    • Use the plastic opening tool to remove the chip connected by magnetic strip to the screen.
    • Remove circuit board.
  7. Motorola W315 Keypad Replacement, Keypad: 步骤 8 中的图像 1,3 Motorola W315 Keypad Replacement, Keypad: 步骤 8 中的图像 2,3 Motorola W315 Keypad Replacement, Keypad: 步骤 8 中的图像 3,3
    • Apply pressure to the side buttons to remove them from the frame.
    • Turn the device over and push the keypad to loosen it from the frame.
    • Turn the device over again and gently pull the keypad away from the frame.
    • Warning: Keypad may not respond due to unclean button contacts, make sure the button contacts remain clean throughout the disassembly and reassembly of the phone.
结论
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
于03/26/14注册
501 声望
创作了5篇指南
团队
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G3
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 168
