跳转到主内容
Motorola W315 Headphone Jack Replacement
你所需要的
  1. Motorola W315 Headphone Jack Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Insert the new battery.
  3. Motorola W315 Headphone Jack Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Headphone Jack Replacement: 步骤 5 中的图像 1,3 Motorola W315 Headphone Jack Replacement: 步骤 5 中的图像 2,3 Motorola W315 Headphone Jack Replacement: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Headphone Jack Replacement, Headphone Jack: 步骤 6 中的图像 1,2 Motorola W315 Headphone Jack Replacement, Headphone Jack: 步骤 6 中的图像 2,2
    • Use the pry bar to carefully remove the headphone jack.
结论
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
于03/26/14注册
399 声望
创作了4篇指南
团队
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G3
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 129
