跳转到主内容
Motorola V710 Logic Board Replacement
你所需要的
  1. Motorola V710 Logic Board Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V710 Logic Board Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V710 Logic Board Replacement, Battery: 步骤 1 中的图像 3,3
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Logic Board Replacement: 步骤 2 中的图像 1,3 Motorola V710 Logic Board Replacement: 步骤 2 中的图像 2,3 Motorola V710 Logic Board Replacement: 步骤 2 中的图像 3,3
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Logic Board Replacement, Logic Board: 步骤 3 中的图像 1,2 Motorola V710 Logic Board Replacement, Logic Board: 步骤 3 中的图像 2,2
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Logic Board Replacement: 步骤 4 中的图像 1,2 Motorola V710 Logic Board Replacement: 步骤 4 中的图像 2,2
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Logic Board Replacement: 步骤 5 中的图像 1,3 Motorola V710 Logic Board Replacement: 步骤 5 中的图像 2,3 Motorola V710 Logic Board Replacement: 步骤 5 中的图像 3,3
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Logic Board Replacement: 步骤 6 中的图像 1,2 Motorola V710 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Logic Board Replacement: 步骤 7 中的图像 1,2 Motorola V710 Logic Board Replacement: 步骤 7 中的图像 2,2
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Logic Board Replacement: 步骤 8 中的图像 1,3 Motorola V710 Logic Board Replacement: 步骤 8 中的图像 2,3 Motorola V710 Logic Board Replacement: 步骤 8 中的图像 3,3
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Logic Board Replacement: 步骤 9 中的图像 1,1
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Logic Board Replacement: 步骤 10 中的图像 1,2 Motorola V710 Logic Board Replacement: 步骤 10 中的图像 2,2
    • Remove the logic board.
结论
另外一个人完成了本指南。
Karl Sanders
于01/26/10注册
8 声望
创作了7篇指南
团队
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G49
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,996
