跳转到主内容
加入维修社区 - 创建账户
Motorola V710 LCD screen replacement
你所需要的
    1. Motorola V710 LCD screen replacement, Screen: 步骤 1 中的图像 1,3 Motorola V710 LCD screen replacement, Screen: 步骤 1 中的图像 2,3 Motorola V710 LCD screen replacement, Screen: 步骤 1 中的图像 3,3
      • Insert the spudger between the gray and black plates of the screen casing.
      • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
      • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
      询问修复机器人
      添加评论
    2. Motorola V710 LCD screen replacement: 步骤 2 中的图像 1,2 Motorola V710 LCD screen replacement: 步骤 2 中的图像 2,2
      • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
      • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
      • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
      询问修复机器人
      添加评论
    3. Motorola V710 LCD screen replacement: 步骤 3 中的图像 1,2 Motorola V710 LCD screen replacement: 步骤 3 中的图像 2,2
      • Orient the phone so that the main screen is facing upward.
      • Locate the hinge casing, a dark gray piece that covers the hinge.
      • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
      询问修复机器人
      添加评论
    4. Motorola V710 LCD screen replacement: 步骤 4 中的图像 1,2 Motorola V710 LCD screen replacement: 步骤 4 中的图像 2,2
      • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
      询问修复机器人
      添加评论
    5. Motorola V710 LCD screen replacement: 步骤 5 中的图像 1,2 Motorola V710 LCD screen replacement: 步骤 5 中的图像 2,2
      • Insert the spudger under the screen and pry the screen forward.
      • Remove the plug on the back of the screen that connects it to the camera.
      询问修复机器人
      添加评论
    6. Motorola V710 LCD screen replacement: 步骤 6 中的图像 1,2 Motorola V710 LCD screen replacement: 步骤 6 中的图像 2,2
      • Use the spudger to remove the screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G49
5 名成员
创作了48篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 2,397
