跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Motorola V60s Logic Board Replacement
你所需要的
  1. Motorola V60s Logic Board Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V60s Logic Board Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V60s Logic Board Replacement, Battery: 步骤 1 中的图像 3,3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Logic Board Replacement: 步骤 2 中的图像 1,2 Motorola V60s Logic Board Replacement: 步骤 2 中的图像 2,2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Logic Board Replacement, Logic Board: 步骤 3 中的图像 1,2 Motorola V60s Logic Board Replacement, Logic Board: 步骤 3 中的图像 2,2
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Logic Board Replacement: 步骤 4 中的图像 1,3 Motorola V60s Logic Board Replacement: 步骤 4 中的图像 2,3 Motorola V60s Logic Board Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Logic Board Replacement: 步骤 5 中的图像 1,3 Motorola V60s Logic Board Replacement: 步骤 5 中的图像 2,3 Motorola V60s Logic Board Replacement: 步骤 5 中的图像 3,3
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Logic Board Replacement: 步骤 6 中的图像 1,3 Motorola V60s Logic Board Replacement: 步骤 6 中的图像 2,3 Motorola V60s Logic Board Replacement: 步骤 6 中的图像 3,3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Logic Board Replacement: 步骤 7 中的图像 1,2 Motorola V60s Logic Board Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
结论
另外一个人完成了本指南。
Eric Freeman
于01/26/10注册
10 声望
创作了7篇指南
团队
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G48
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,865
