当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Push in release lever towards top of phone, then use blue spudger to pry case off.
After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
Set cover aside in a safe location.
Carefully grab battery towards bottom of phone.
Lift from bottom and take out of phone, set aside in a safe location.
Starting from left side of phone, remove side buttons and place aside.
Note: There should be three buttons. One on each side, and the top.
Return phone to starting orientation when done.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
