本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will describe how to replace the numbered cover buttons in the in-hand partition of the Motorola V60.
你所需要的
Push in release lever towards top of phone, then use blue spudger to pry case off.
After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
Set cover aside in a safe location.
Unscrew four corner screws with T6 screwdriver.
Note: The two top screws are short and silver. The two bottom screws are black and long.
即将完成!
结论
