跳转到主内容
加入维修社区 - 创建账户
Motorola V60s Button Key Pad Replacement
你所需要的
  1. Motorola V60s Button Key Pad Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V60s Button Key Pad Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V60s Button Key Pad Replacement, Battery: 步骤 1 中的图像 3,3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
    询问修复机器人
    添加评论
  2. Motorola V60s Button Key Pad Replacement: 步骤 2 中的图像 1,2 Motorola V60s Button Key Pad Replacement: 步骤 2 中的图像 2,2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
    询问修复机器人
    添加评论
  3. Motorola V60s Button Key Pad Replacement, Motherboard: 步骤 3 中的图像 1,2 Motorola V60s Button Key Pad Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
    询问修复机器人
    添加评论
  4. Motorola V60s Button Key Pad Replacement: 步骤 4 中的图像 1,3 Motorola V60s Button Key Pad Replacement: 步骤 4 中的图像 2,3 Motorola V60s Button Key Pad Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
    询问修复机器人
    添加评论
  5. Motorola V60s Button Key Pad Replacement: 步骤 5 中的图像 1,3 Motorola V60s Button Key Pad Replacement: 步骤 5 中的图像 2,3 Motorola V60s Button Key Pad Replacement: 步骤 5 中的图像 3,3
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
    询问修复机器人
    添加评论
  6. Motorola V60s Button Key Pad Replacement: 步骤 6 中的图像 1,3 Motorola V60s Button Key Pad Replacement: 步骤 6 中的图像 2,3 Motorola V60s Button Key Pad Replacement: 步骤 6 中的图像 3,3
    • Gently remove orange ribbon cable by prying up with spudger.
    询问修复机器人
    添加评论
  7. Motorola V60s Button Key Pad Replacement: 步骤 7 中的图像 1,2 Motorola V60s Button Key Pad Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
    询问修复机器人
    添加评论
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: 步骤 8 中的图像 1,2 Motorola V60s Button Key Pad Replacement, Button Key Board: 步骤 8 中的图像 2,2
    • Insert an opening tool under the button board and gently lift.
    询问修复机器人
    添加评论
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: 步骤 9 中的图像 1,2 Motorola V60s Button Key Pad Replacement, Button Key Pad: 步骤 9 中的图像 2,2
    • Life button keypad with spudger and set aside.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Eric Freeman
于01/26/10注册
12 声望
创作了7篇指南
团队
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G48
4 名成员
创作了27篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 3,316
