当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the phone over so the back cover is facing up.
Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
Pry up the back plate from the phone.
Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
Simultaneously press the highlighted buttons on both sides of phone.
Separate the back plate from the rest of phone.
Do not pull the wire connecting the front and back plates.
取消:我没有完成这个指南。
与10其他贡献者
于04/26/10注册
43 声望
创作了7篇指南
徽章: 8
+ 5更多徽章
CPSU-GARNER-S10S30G40
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,525
