跳转到主内容
Motorola V60i Back Plate Replacement
你所需要的
  1. Motorola V60i Back Plate Replacement, Battery: 步骤 1 中的图像 1,2 Motorola V60i Back Plate Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Back Plate Replacement: 步骤 2 中的图像 1,2 Motorola V60i Back Plate Replacement: 步骤 2 中的图像 2,2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Back Plate Replacement, Back Plate: 步骤 3 中的图像 1,1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Back Plate Replacement: 步骤 4 中的图像 1,2 Motorola V60i Back Plate Replacement: 步骤 4 中的图像 2,2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Back Plate Replacement: 步骤 5 中的图像 1,1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
结论
团队
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G40
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,525
