当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Depress the silver button.
Pull from top of phone to lift the cover.
Hold battery from both sides at the bottom.
Push upwards and gently lift to remove.
Remove 4 screws from corners using T-6 screwdriver.
NOTE: Bottom two screws are gold.
NOTE: Make sure screws return to correct place when reassembling.
Use a plastic opening tool to pry up back cover from the two side clips.
NOTE: sticker might be attached to rest of phone.
Remove the back cover.
Use a plastic opening tool to gently remove the orange ribbon cable.
Lift up the main logic board to remove.
取消:我没有完成这个指南。
与7其他贡献者
于04/10/10注册
1 声望
创作了5篇指南
徽章: 4
+1个徽章
CPSU-AMIDO-S10S25G86
5 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 2,349
