跳转到主内容
Motorola V60c Keypad and Keypad Logic Board Replacement
你所需要的
  1. Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: 步骤 1 中的图像 1,2 Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 2 中的图像 1,2 Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 2 中的图像 2,2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Keypad and Keypad Logic Board Replacement, Keypad and Keypad Logic Board: 步骤 3 中的图像 1,1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 4 中的图像 1,2 Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 4 中的图像 2,2
    • Use plastic opening tool to pry up back cover from two side clips.
    • NOTE: Sticker might be attached to rest of phone.
  5. Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 5 中的图像 1,1
    • Remove the back cover.
  6. Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 6 中的图像 1,2 Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 7 中的图像 1,2 Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 7 中的图像 2,2
    • Remove the keypad logic board.
    • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  8. Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 8 中的图像 1,3 Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 8 中的图像 2,3 Motorola V60c Keypad and Keypad Logic Board Replacement: 步骤 8 中的图像 3,3
    • Remove the keypad.
结论
Ryan Kuroiwa
于04/10/10注册
1 声望
创作了5篇指南
团队
Cal Poly, Team 25-86, Amido Spring 2010 Cal Poly, Team 25-86, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G86
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 2,213
