当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using a plastic opening tool, pry or lift open the pink door shown.
After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
