跳转到主内容
Motorola V557 Screen Replacement
你所需要的
  1. Motorola V557 Screen Replacement, Faceplate: 步骤 1 中的图像 1,3 Motorola V557 Screen Replacement, Faceplate: 步骤 1 中的图像 2,3 Motorola V557 Screen Replacement, Faceplate: 步骤 1 中的图像 3,3
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  2. Motorola V557 Screen Replacement: 步骤 2 中的图像 1,2 Motorola V557 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3.8 mm T-6 Torx screws.
  3. Motorola V557 Screen Replacement: 步骤 3 中的图像 1,2 Motorola V557 Screen Replacement: 步骤 3 中的图像 2,2
    • Separate the cover from the edges using a plastic opening tool.
  4. Motorola V557 Screen Replacement: 步骤 4 中的图像 1,2 Motorola V557 Screen Replacement: 步骤 4 中的图像 2,2
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  5. Motorola V557 Screen Replacement, Camera: 步骤 5 中的图像 1,1
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  6. Motorola V557 Screen Replacement: 步骤 6 中的图像 1,2 Motorola V557 Screen Replacement: 步骤 6 中的图像 2,2
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  7. Motorola V557 Screen Replacement: 步骤 7 中的图像 1,2 Motorola V557 Screen Replacement: 步骤 7 中的图像 2,2
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  8. Motorola V557 Screen Replacement: 步骤 8 中的图像 1,2 Motorola V557 Screen Replacement: 步骤 8 中的图像 2,2
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  9. Motorola V557 Screen Replacement: 步骤 9 中的图像 1,3 Motorola V557 Screen Replacement: 步骤 9 中的图像 2,3 Motorola V557 Screen Replacement: 步骤 9 中的图像 3,3
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  10. Motorola V557 Screen Replacement: 步骤 10 中的图像 1,2 Motorola V557 Screen Replacement: 步骤 10 中的图像 2,2
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
  11. Motorola V557 Screen Replacement, Screen: 步骤 11 中的图像 1,3 Motorola V557 Screen Replacement, Screen: 步骤 11 中的图像 2,3 Motorola V557 Screen Replacement, Screen: 步骤 11 中的图像 3,3
    • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
    • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
结论
Blair Frandeen
于10/02/10注册
19 声望
创作了4篇指南
团队
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G50
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,735
