跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This section will show how to separate the pieces of the main case to reveal the internal components.
  1. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery.
    • Push down on the silver button while sliding the back plate down to reveal the battery.
  2. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
    • Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
  3. Move the the metal slider towards the top of the phone until it clicks out of its original position. Slide out and remove the SIM card. Slide out and remove the SIM card.
    • Move the the metal slider towards the top of the phone until it clicks out of its original position.
    • Slide out and remove the SIM card.
  4. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  5. Grip the antenna and twist it counterclockwise to loosen it. When it has been loosened all the way, pull gently to remove the antenna piece.
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  6. Remove the screw covers over the two top screws by prying gently with a pin. The large cover in the upper left of the back plate has no screw behind it, so should not be removed. The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
    • Remove the screw covers over the two top screws by prying gently with a pin.
    • The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
  7. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws.
    • Remove all four 6.0 mm Torx screws.
  8. Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs. Separate and detach the rear casing. Separate and detach the rear casing.
    • Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs.
    • Separate and detach the rear casing.
结论
Alex Georges
于2010年10月02日注册
25 信誉积分
创作了4篇指南
团队
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G50
4 名成员
创作了24篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,295
