跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Motorola V557 Motherboard Replacement
你所需要的
  1. Motorola V557 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V557 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V557 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Motherboard Replacement: 步骤 2 中的图像 1,2 Motorola V557 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Motherboard Replacement, SIM Card: 步骤 3 中的图像 1,3 Motorola V557 Motherboard Replacement, SIM Card: 步骤 3 中的图像 2,3 Motorola V557 Motherboard Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Motherboard Replacement, Antenna: 步骤 4 中的图像 1,2 Motorola V557 Motherboard Replacement, Antenna: 步骤 4 中的图像 2,2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Motherboard Replacement, Rear Casing: 步骤 5 中的图像 1,3 Motorola V557 Motherboard Replacement, Rear Casing: 步骤 5 中的图像 2,3 Motorola V557 Motherboard Replacement, Rear Casing: 步骤 5 中的图像 3,3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Motherboard Replacement: 步骤 6 中的图像 1,3 Motorola V557 Motherboard Replacement: 步骤 6 中的图像 2,3 Motorola V557 Motherboard Replacement: 步骤 6 中的图像 3,3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Motherboard Replacement: 步骤 7 中的图像 1,3 Motorola V557 Motherboard Replacement: 步骤 7 中的图像 2,3 Motorola V557 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
  8. Motorola V557 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,3 Motorola V557 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,3 Motorola V557 Motherboard Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Separate the front ribbon cable from the board with a plastic opening tool.
  9. Motorola V557 Motherboard Replacement: 步骤 9 中的图像 1,3 Motorola V557 Motherboard Replacement: 步骤 9 中的图像 2,3 Motorola V557 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard.
    • Lift out the motherboard only after all cables have been disconnected. Try to touch it only from the sides.
结论
2等其他人完成本指南。
Chad Brantley
于10/06/10注册
32 声望
创作了2篇指南
团队
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G50
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,848
