简介
The motherboard acts as the "brain" of the phone. Any damage the phone sustains to this region generally causes major malfunctions; thus, you should take extra care while removing/replacing this piece.
配件
无需配件。
Push down on the silver button while sliding the back plate down to reveal the battery.
Move the the metal slider towards the top of the phone until it clicks out of its original position.
Slide out and remove the SIM card.
Grip the antenna and twist it counterclockwise to loosen it.
When it has been loosened all the way, pull gently to remove the antenna piece.
Remove the screw covers over the two top screws by prying gently with a pin.
The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
2等其他人完成本指南。
