跳转到主内容
Motorola V557 External Speaker Replacement
你所需要的
  1. Motorola V557 External Speaker Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V557 External Speaker Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V557 External Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 External Speaker Replacement: 步骤 2 中的图像 1,2 Motorola V557 External Speaker Replacement: 步骤 2 中的图像 2,2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 External Speaker Replacement, SIM Card: 步骤 3 中的图像 1,3 Motorola V557 External Speaker Replacement, SIM Card: 步骤 3 中的图像 2,3 Motorola V557 External Speaker Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 External Speaker Replacement, Antenna: 步骤 4 中的图像 1,2 Motorola V557 External Speaker Replacement, Antenna: 步骤 4 中的图像 2,2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 External Speaker Replacement, Rear Casing: 步骤 5 中的图像 1,3 Motorola V557 External Speaker Replacement, Rear Casing: 步骤 5 中的图像 2,3 Motorola V557 External Speaker Replacement, Rear Casing: 步骤 5 中的图像 3,3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 External Speaker Replacement: 步骤 6 中的图像 1,3 Motorola V557 External Speaker Replacement: 步骤 6 中的图像 2,3 Motorola V557 External Speaker Replacement: 步骤 6 中的图像 3,3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 External Speaker Replacement: 步骤 7 中的图像 1,3 Motorola V557 External Speaker Replacement: 步骤 7 中的图像 2,3 Motorola V557 External Speaker Replacement: 步骤 7 中的图像 3,3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
  8. Motorola V557 External Speaker Replacement, Headphone Jack: 步骤 8 中的图像 1,3 Motorola V557 External Speaker Replacement, Headphone Jack: 步骤 8 中的图像 2,3 Motorola V557 External Speaker Replacement, Headphone Jack: 步骤 8 中的图像 3,3
    • Lastly, using a push pin, lift out and to the left to release the headphone jack assembly.
    • Insert the new headphone jack assembly and repeat these steps in reverse order.
  9. Motorola V557 External Speaker Replacement, External Speaker: 步骤 9 中的图像 1,2 Motorola V557 External Speaker Replacement, External Speaker: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using metal tweezers, lift out the black plastic support piece from beneath the headphone jack.
  10. Motorola V557 External Speaker Replacement: 步骤 10 中的图像 1,3 Motorola V557 External Speaker Replacement: 步骤 10 中的图像 2,3 Motorola V557 External Speaker Replacement: 步骤 10 中的图像 3,3
    • Separate the speaker from the casing by pushing with a pin from the back (external) side, through the openings in the casing.
    • Be gentle! The wire mesh is durable, but it might suffer damage if you push too hard with the pin.
结论
Alex Georges
于10/02/10注册
40 声望
创作了4篇指南
团队
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G50
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 928
