跳转到主内容
简介
Prerequisites: Battery, Faceplate
  1. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery.
    • Push down on the silver button while sliding the back plate down to reveal the battery.
  2. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
    • Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
  3. Remove the four rubber stoppers from around the screen with a pin to reveal four screws. Remove the four rubber stoppers from around the screen with a pin to reveal four screws. Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  4. Remove the four 3.8 mm T-6 Torx screws. Remove the four 3.8 mm T-6 Torx screws.
    • Remove the four 3.8 mm T-6 Torx screws.
  5. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    现在开始购物
    iPhone X Fix Kits
    现在开始购物
  6. Separate the cover from the edges using a plastic opening tool. Separate the cover from the edges using a plastic opening tool.
    • Separate the cover from the edges using a plastic opening tool.
  7. With the edges separated, close the phone and lift off the faceplate with your fingers. With the edges separated, close the phone and lift off the faceplate with your fingers.
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  8. Gently peel off the plastic film from the metal plate above the camera lens as shown.
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  9. Insert the spudger into the slots marked and gently pry upwards to remove the metal cover. Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  10. Lift and peel back the tape attaching metal casing to body of the phone. Gently lift the metal cover and remove to expose the circuit board.
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  11. Using a plastic opening tool, pry or lift open the pink door shown. After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  12. Use a plastic opening tool to dislodge and remove the rubber camera cover. Use a plastic opening tool to dislodge and remove the rubber camera cover. Use a plastic opening tool to dislodge and remove the rubber camera cover.
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  13. Lift the top ribbon cable, with camera attached, up and away from the rest of the phone. Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
结论
另外一个人完成了本指南。
Matthew Sanders
于2010年10月04日注册
31 信誉积分
创作了2篇指南
团队
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G50
4 名成员
创作了24篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,559
