当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
On the phone's face, remove the four rubber caps from the screw covers using a spudger.
Unscrew the four cover screws using a T6 Torx screwdriver, turning counterclockwise.
Loosen and remove the protective cover using a plastic opening tool.
Gently loosen the second protective cover with the plastic opening tool.
Carefully remove the protective cover from the circuitry.
Slowly peel the black rubber gasket off of the circuit board.
Carefully move the camera out of the way using your hand.
Use a flat tool to disconnect the upper and lower circuit boards.
Gently slip the copper strip out from under the circuitry by using your hand.
Pry out the speaker using your fingers.
取消:我没有完成这个指南。
与8其他贡献者
于10/29/09注册
105 声望
创作了6篇指南
徽章: 9
+ 6更多徽章
CPSU-MANESS-F09S6G6
4 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,716
