跳转到主内容
Motorola V551 Earpiece Speaker Replacement
你所需要的
  1. Motorola V551 Earpiece Speaker Replacement, Screen: 步骤 1 中的图像 1,3 Motorola V551 Earpiece Speaker Replacement, Screen: 步骤 1 中的图像 2,3 Motorola V551 Earpiece Speaker Replacement, Screen: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • On the phone's face, remove the four rubber caps from the screw covers using a spudger.
  2. Motorola V551 Earpiece Speaker Replacement: 步骤 2 中的图像 1,1
    • Unscrew the four cover screws using a T6 Torx screwdriver, turning counterclockwise.
  3. Motorola V551 Earpiece Speaker Replacement: 步骤 3 中的图像 1,2 Motorola V551 Earpiece Speaker Replacement: 步骤 3 中的图像 2,2
    • Loosen and remove the protective cover using a plastic opening tool.
  4. Motorola V551 Earpiece Speaker Replacement: 步骤 4 中的图像 1,2 Motorola V551 Earpiece Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently loosen the second protective cover with the plastic opening tool.
  5. Motorola V551 Earpiece Speaker Replacement: 步骤 5 中的图像 1,3 Motorola V551 Earpiece Speaker Replacement: 步骤 5 中的图像 2,3 Motorola V551 Earpiece Speaker Replacement: 步骤 5 中的图像 3,3
    • Carefully remove the protective cover from the circuitry.
    • Slowly peel the black rubber gasket off of the circuit board.
    • Carefully move the camera out of the way using your hand.
    • Use a flat tool to disconnect the upper and lower circuit boards.
  6. Motorola V551 Earpiece Speaker Replacement: 步骤 6 中的图像 1,3 Motorola V551 Earpiece Speaker Replacement: 步骤 6 中的图像 2,3 Motorola V551 Earpiece Speaker Replacement: 步骤 6 中的图像 3,3
    • Gently slip the copper strip out from under the circuitry by using your hand.
  7. Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 7 中的图像 1,3 Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 7 中的图像 2,3 Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 7 中的图像 3,3
    • Pry out the speaker using your fingers.
结论
gregatron
于10/29/09注册
105 声望
创作了6篇指南
团队
Cal Poly, Team 6-6, Maness Fall 2009 Cal Poly, Team 6-6, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G6
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,716
