跳转到主内容
Motorola V325 Screen and External Display Disassembly
你所需要的
  1. Motorola V325 Screen and External Display Disassembly, External Casing: 步骤 1 中的图像 1,3 Motorola V325 Screen and External Display Disassembly, External Casing: 步骤 1 中的图像 2,3 Motorola V325 Screen and External Display Disassembly, External Casing: 步骤 1 中的图像 3,3
    • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
    • Lift the panel off of the phone.
  2. Motorola V325 Screen and External Display Disassembly: 步骤 2 中的图像 1,3 Motorola V325 Screen and External Display Disassembly: 步骤 2 中的图像 2,3 Motorola V325 Screen and External Display Disassembly: 步骤 2 中的图像 3,3
    • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  3. Motorola V325 Screen and External Display Disassembly: 步骤 3 中的图像 1,2 Motorola V325 Screen and External Display Disassembly: 步骤 3 中的图像 2,2
    • Unscrew the four screws using the T6 Torx Screwdriver.
  4. Motorola V325 Screen and External Display Disassembly: 步骤 4 中的图像 1,3 Motorola V325 Screen and External Display Disassembly: 步骤 4 中的图像 2,3 Motorola V325 Screen and External Display Disassembly: 步骤 4 中的图像 3,3
    • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
  5. Motorola V325 Screen and External Display Disassembly, Motorola V325 Screen and External Display Disassembly: 步骤 5 中的图像 1,2 Motorola V325 Screen and External Display Disassembly, Motorola V325 Screen and External Display Disassembly: 步骤 5 中的图像 2,2
    • After removing the external casing, there are no more screws holding on the gray metal plate. Carefully separate the gray plate from the rest of the phone by simply lifting it off.
  6. Motorola V325 Screen and External Display Disassembly: 步骤 6 中的图像 1,3 Motorola V325 Screen and External Display Disassembly: 步骤 6 中的图像 2,3 Motorola V325 Screen and External Display Disassembly: 步骤 6 中的图像 3,3
    • Next separate the screen from the phone, pulling it away slowly as it will still be attached by a yellow ribbon.
    • A yellow ribbon attaches to the area boxed in blue. Unclip the yellow ribbon from the circuit board using your fingers.
结论
另外一个人完成了本指南。
Danny Breslow
于01/14/10注册
19 声望
撰写一个指南
团队
Cal Poly, Team 4-15, Forte Winter 2010 Cal Poly, Team 4-15, Forte Winter 2010 的会员
CPSU-FORTE-W10S4G15
5 名成员
创作了8篇指南
一条评论
This was SO very helpful! I had dropped my V325 phone the other day and when I opened it, the screen was dark :( However, it still dialed and received calls so I was HOPING that a connection to the screen was the issue. Following this guide, I was able to get to the back of the display and sure enough, a connection was out of place. Put it back together and everything is working great!
Thanks so much!
Bob
Bob - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,822
