跳转到主内容
Motorola V276 Speaker Replacement
你所需要的
  1. Motorola V276 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Speaker Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Speaker Replacement: 步骤 3 中的图像 1,2 Motorola V276 Speaker Replacement: 步骤 3 中的图像 2,2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
  5. Motorola V276 Speaker Replacement: 步骤 5 中的图像 1,1
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  6. Motorola V276 Speaker Replacement: 步骤 6 中的图像 1,3 Motorola V276 Speaker Replacement: 步骤 6 中的图像 2,3 Motorola V276 Speaker Replacement: 步骤 6 中的图像 3,3
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Speaker Replacement: 步骤 7 中的图像 1,2 Motorola V276 Speaker Replacement: 步骤 7 中的图像 2,2
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
  8. Motorola V276 Speaker Replacement: 步骤 8 中的图像 1,2 Motorola V276 Speaker Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
  9. Motorola V276 Speaker Replacement: 步骤 9 中的图像 1,1
    • Using a spudger, remove the speaker
结论
Kyle Klitzner
于04/11/10注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G96
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,024
