当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Using the plastic opening tool, pry off the top faceplate.
Place the tool in the small crack that runs along the side of the phone and pry.
Using the T6 Torx Screwdriver remove all 4 small screws.
Remove silver plate from phone.
Using the spudger remove the plastic camera casing
Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
Use Spudger or hands to detach flex cable from front screen logic board
Use a plastic opening tool to lift the small black flap to unlock the screen from the motherboard.
Using your fingers, carefully pull out the small LCD display screen.
Remove the small LCD display screen completely from the green logic board.
取消:我没有完成这个指南。
与6其他贡献者
于04/11/10注册
1 声望
创作了3篇指南
徽章: 3
CPSU-AMIDO-S10S27G96
4 名成员
创作了15篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 15
总计 2,729
