跳转到主内容
Motorola V276 Motherboard Replacement
你所需要的
  1. Motorola V276 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Motherboard Replacement: 步骤 3 中的图像 1,2 Motorola V276 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
  5. Motorola V276 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
  6. Motorola V276 Motherboard Replacement: 步骤 6 中的图像 1,3 Motorola V276 Motherboard Replacement: 步骤 6 中的图像 2,3 Motorola V276 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Motherboard Replacement: 步骤 7 中的图像 1,3 Motorola V276 Motherboard Replacement: 步骤 7 中的图像 2,3 Motorola V276 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
  8. Motorola V276 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Gently peel back the motherboard from the main part of the phone.
结论
团队
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G96
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,060
