跳转到主内容
Motorola V2397 Motherboard/Screen Replacement
你所需要的
  1. Motorola V2397 Motherboard/Screen Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V2397 Motherboard/Screen Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V2397 Motherboard/Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Motherboard/Screen Replacement: 步骤 2 中的图像 1,2 Motorola V2397 Motherboard/Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Motherboard/Screen Replacement, Back Cover: 步骤 3 中的图像 1,2 Motorola V2397 Motherboard/Screen Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Motherboard/Screen Replacement: 步骤 4 中的图像 1,2 Motorola V2397 Motherboard/Screen Replacement: 步骤 4 中的图像 2,2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Motherboard/Screen Replacement, Phone: 步骤 5 中的图像 1,2 Motorola V2397 Motherboard/Screen Replacement, Phone: 步骤 5 中的图像 2,2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  6. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: 步骤 6 中的图像 1,2 Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: 步骤 6 中的图像 2,2
    • Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
    • Carefully separate the screen from the motherboard
    • Note the cable connecting the screen to the motherboard. Do not pull the screen too far from the motherboard or you may damage the cable
  7. Motorola V2397 Motherboard/Screen Replacement: 步骤 7 中的图像 1,2 Motorola V2397 Motherboard/Screen Replacement: 步骤 7 中的图像 2,2
    • Lift the flap of the connector on the motherboard using a spudger
    • Carefully remove the FFC cable from the connector
    • The screen should now be free from the motherboard
结论
Chris
于01/13/15注册
501 声望
创作了5篇指南
团队
USF Tampa, Team 1-6, Sullivan Winter 2015 USF Tampa, Team 1-6, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G6
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 137
