跳转到主内容
Motorola V2397 Front Cover Replacement
你所需要的
  1. Motorola V2397 Front Cover Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V2397 Front Cover Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V2397 Front Cover Replacement, Battery: 步骤 1 中的图像 3,3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Front Cover Replacement: 步骤 2 中的图像 1,2 Motorola V2397 Front Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Front Cover Replacement, Back Cover: 步骤 3 中的图像 1,2 Motorola V2397 Front Cover Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Front Cover Replacement: 步骤 4 中的图像 1,2 Motorola V2397 Front Cover Replacement: 步骤 4 中的图像 2,2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Front Cover Replacement, Side Buttons: 步骤 5 中的图像 1,2 Motorola V2397 Front Cover Replacement, Side Buttons: 步骤 5 中的图像 2,2
    • Lift and remove buttons by hand
  6. Motorola V2397 Front Cover Replacement, Phone: 步骤 6 中的图像 1,2 Motorola V2397 Front Cover Replacement, Phone: 步骤 6 中的图像 2,2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  7. Motorola V2397 Front Cover Replacement, Keypad: 步骤 7 中的图像 1,3 Motorola V2397 Front Cover Replacement, Keypad: 步骤 7 中的图像 2,3 Motorola V2397 Front Cover Replacement, Keypad: 步骤 7 中的图像 3,3
    • Grip the top of the rubber keypad with your thumb and index finger
    • While holding the keypad start to peel it back from the front cover until the keypad is completely detached
  8. Motorola V2397 Front Cover Replacement, Speaker: 步骤 8 中的图像 1,2 Motorola V2397 Front Cover Replacement, Speaker: 步骤 8 中的图像 2,2
    • Use the iFixit opening tool to lift the speaker off the front cover.
  9. Motorola V2397 Front Cover Replacement, Front Cover: 步骤 9 中的图像 1,2 Motorola V2397 Front Cover Replacement, Front Cover: 步骤 9 中的图像 2,2
    • Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
结论
Connor
于01/13/15注册
201 声望
创作了2篇指南
团队
USF Tampa, Team 1-6, Sullivan Winter 2015 USF Tampa, Team 1-6, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G6
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 116
