跳转到主内容
Motorola V180 LCD screen and connector ribbon replacement
你所需要的
  1. Motorola V180 LCD screen and connector ribbon replacement, Connector Ribbon: 步骤 1 中的图像 1,1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 LCD screen and connector ribbon replacement: 步骤 2 中的图像 1,1
    • Remove the four screws securing the front cover.
  3. Motorola V180 LCD screen and connector ribbon replacement: 步骤 3 中的图像 1,1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 LCD screen and connector ribbon replacement: 步骤 4 中的图像 1,1
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 LCD screen and connector ribbon replacement: 步骤 5 中的图像 1,1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 LCD screen and connector ribbon replacement: 步骤 6 中的图像 1,1
    • Use a soldering iron to detach the connector ribbon from the phone.
  7. Motorola V180 LCD screen and connector ribbon replacement, Motherboard: 步骤 7 中的图像 1,3 Motorola V180 LCD screen and connector ribbon replacement, Motherboard: 步骤 7 中的图像 2,3 Motorola V180 LCD screen and connector ribbon replacement, Motherboard: 步骤 7 中的图像 3,3
    • Power off the Motorola V180.
    • Flip the phone over to its back side.
    • Hold down the button and slide off the back cover.
    • Remove the battery.
  8. Motorola V180 LCD screen and connector ribbon replacement: 步骤 8 中的图像 1,3 Motorola V180 LCD screen and connector ribbon replacement: 步骤 8 中的图像 2,3 Motorola V180 LCD screen and connector ribbon replacement: 步骤 8 中的图像 3,3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  9. Motorola V180 LCD screen and connector ribbon replacement: 步骤 9 中的图像 1,2 Motorola V180 LCD screen and connector ribbon replacement: 步骤 9 中的图像 2,2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard.
  10. Motorola V180 LCD screen and connector ribbon replacement, Screen and Connector Ribbon: 步骤 10 中的图像 1,2 Motorola V180 LCD screen and connector ribbon replacement, Screen and Connector Ribbon: 步骤 10 中的图像 2,2
    • Now that the connector ribbon is loose, the screen (white part) can swing away.
    • Some of the black "tape" can be peeled back, but the screen is still attached. Further work may be necessary to fully separate this part.
  11. Motorola V180 LCD screen and connector ribbon replacement: 步骤 11 中的图像 1,2 Motorola V180 LCD screen and connector ribbon replacement: 步骤 11 中的图像 2,2
    • Slide out the part of the connector ribbon that was just attached to the motherboard through this narrow slot in the phone.
    • This may require some effort as it is a tight fit, so proceed with caution to avoid tearing the ribbon while maneuvering it through the slot.
    • Once the connector ribbon is successfully removed from the slot, proceed to remove the entire unit from the phone.
结论
Tyler Knisley
于05/07/10注册
1 声望
创作了7篇指南
团队
Cal Poly, Team 6-16, Maness Spring 2010 Cal Poly, Team 6-16, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G16
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 30
总计 3,319
