跳转到主内容
Motorola V180 Motherboard Replacement
你所需要的
  1. Motorola V180 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Motorola V180 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Motorola V180 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: 步骤 2 中的图像 1,3 Motorola V180 Motherboard Replacement, Motherboard: 步骤 2 中的图像 2,3 Motorola V180 Motherboard Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: 步骤 3 中的图像 1,2 Motorola V180 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
结论
Tyler Knisley
于05/07/10注册
1 声望
创作了7篇指南
团队
Cal Poly, Team 6-16, Maness Spring 2010 Cal Poly, Team 6-16, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G16
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,549
