跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The two way radio speaker is responsible for broadcasting the signal received, making it a very important part. Follow the steps below to properly replace the speaker of the radio.
  1. Remove the back battery cover by pressing the tab to the left, and lifting.
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Remove the batteries currently in the radio.
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Turn the Volume knob to the off position.
    • Turn the Volume knob to the off position.
  4. Firmly grasp and pull back on the volume knob. The knob should come off smoothly. This may require some twisting and force.
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  6. Remove the four 3 millimeter T6 Torx screws from the front of the radio.
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  7. Remove the four 3 millimeter T8 Torx screws from the back of the radio. Remove the four 3 millimeter T8 Torx screws from the back of the radio.
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  8. Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides. Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna. Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  9. Gently pull the circuit board away from the front faceplate. Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
  10. To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push. The speaker is glued to the front faceplate, so it may take some force to remove the speaker. The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
    • To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
    • The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
  11. Now the circuit board can be removed from the back faceplate. To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached. To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
    • Now the circuit board can be removed from the back faceplate.
    • To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
  12. Observe the orientation of the speaker as it is removed, so that the new speaker can be installed to face the same way as the old one that you are removing.
    • Observe the orientation of the speaker as it is removed, so that the new speaker can be installed to face the same way as the old one that you are removing.
    • You should end up with just the circuit board and speaker, as seen in the picture.
  13. Remove the wires connecting the speaker to the circuit board with a soldering iron.
    • Remove the wires connecting the speaker to the circuit board with a soldering iron.
    • The new speaker wires can then be connected to the circuitboard with a soldering iron.
    • Be careful when working with a soldering iron, as it can easily cause burns.
    • Make sure the new speaker is connected in the same orientation as the old speaker.
结论
Kayla Brennan
于2014年03月26日注册
719 信誉积分
创作了6篇指南
团队
Clemson, Team 6-4, Benson Spring 2014 Clemson, Team 6-4, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G4
3 名成员
创作了7篇指南
thank you very much!!!!!!!!
deskjet27 - 回复
What glue is used to reattach speaker to front housing?
Jason Schlager - 回复
Speaker model#?...?
Jorge - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 8
过去的30天: 41
总计 2,983
