跳转到主内容
Motorola Talkabout FV700R Front Faceplate Replacement
你所需要的
  1. Motorola Talkabout FV700R Front Faceplate Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Front Faceplate Replacement, Volume Knob: 步骤 3 中的图像 1,1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 4 中的图像 1,2 Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 4 中的图像 2,2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Front Faceplate Replacement, Front Faceplate: 步骤 5 中的图像 1,1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 6 中的图像 1,2 Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 6 中的图像 2,2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 7 中的图像 1,3 Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 7 中的图像 2,3 Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 7 中的图像 3,3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 8 中的图像 1,2 Motorola Talkabout FV700R Front Faceplate Replacement: 步骤 8 中的图像 2,2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
结论
Jack Harrison
于03/26/14注册
188 声望
撰写一个指南
团队
Clemson, Team 6-4, Benson Spring 2014 Clemson, Team 6-4, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G4
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 664
