跳转到主内容
Motorola Talkabout FV700R Button Contact cleaning
你所需要的
  1. Motorola Talkabout FV700R Button Contact cleaning, Battery: 步骤 1 中的图像 1,1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Motorola Talkabout FV700R Button Contact cleaning: 步骤 2 中的图像 1,1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Button Contact cleaning, Volume Knob: 步骤 3 中的图像 1,1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Button Contact cleaning: 步骤 4 中的图像 1,2 Motorola Talkabout FV700R Button Contact cleaning: 步骤 4 中的图像 2,2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Button Contact cleaning, Front Faceplate: 步骤 5 中的图像 1,1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Button Contact cleaning: 步骤 6 中的图像 1,2 Motorola Talkabout FV700R Button Contact cleaning: 步骤 6 中的图像 2,2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Button Contact cleaning: 步骤 7 中的图像 1,3 Motorola Talkabout FV700R Button Contact cleaning: 步骤 7 中的图像 2,3 Motorola Talkabout FV700R Button Contact cleaning: 步骤 7 中的图像 3,3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Button Contact cleaning: 步骤 8 中的图像 1,2 Motorola Talkabout FV700R Button Contact cleaning: 步骤 8 中的图像 2,2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
  9. Motorola Talkabout FV700R Button Contact cleaning, Motorola Talkabout FV700R Button Contact cleaning: 步骤 9 中的图像 1,1
    • The button contacts can be seen in the red box of the picture.
  10. Motorola Talkabout FV700R Button Contact cleaning: 步骤 10 中的图像 1,1
    • Dip q-tip in rubbing isopropyl alcohol, and swab button contacts to clean.
    • Note: Rubbing alcohol will evaporate, and does not need to be wiped off of contacts.
结论
另外一个人完成了本指南。
Kayla Brennan
于03/26/14注册
737 声望
创作了6篇指南
团队
Clemson, Team 6-4, Benson Spring 2014 Clemson, Team 6-4, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G4
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 2,235
