当前版本的文档还未经巡查,您可以查看最新的已查核版本。
At the base of the antenna, use your fingers to unscrew the stem counterclockwise.
The antenna will pull out with little effort.
On the back of the phone, locate the tab with the down arrow.
Using your finger, press the tab and slide the back cover down to release it from the phone.
The fragile wire strip connecting the display housing to the circuit board is located on the right corner of the inner hinge.
In the same direction you would flip open the phone, use your finger to gently lift the circuit board from the plastic keypad.
Using a lens cloth, wipe away any build-up on or between the keys.
Wait for the keypad to dry before reassembling.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
