跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Has your keypad stopped responding due to debris build-up? This guide will show you how to remove the keypad.
配件
没有特定配件。
  1. At the base of the antenna, use your fingers to unscrew the stem counterclockwise.
    • At the base of the antenna, use your fingers to unscrew the stem counterclockwise.
    • The antenna will pull out with little effort.
  2. On the back of the phone, locate the tab with the down arrow.
    • On the back of the phone, locate the tab with the down arrow.
    • Using your finger, press the tab and slide the back cover down to release it from the phone.
  3. Inserting your finger in the recess at the top edge of the battery, pull the battery away from the housing to remove it.
    • Inserting your finger in the recess at the top edge of the battery, pull the battery away from the housing to remove it.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Locate the three screws that secure the back battery housing to the phone.
    • Locate the three screws that secure the back battery housing to the phone.
    • Use a Torx T6 screwdriver to unscrew the screws and then remove them with your fingers.
  6. Using a spudger (not shown), separate by gently prying  the front from the back of the phone housing. Remove the back.
    • Using a spudger (not shown), separate by gently prying the front from the back of the phone housing.
    • Remove the back.
  7. The fragile wire strip connecting the display housing to the circuit board is located on the right corner of the inner hinge.
    • The fragile wire strip connecting the display housing to the circuit board is located on the right corner of the inner hinge.
    • In the same direction you would flip open the phone, use your finger to gently lift the circuit board from the plastic keypad.
  8. While avoiding contact with the inner electronics, use the spudger to lift the plastic keypad from the phone.
    • While avoiding contact with the inner electronics, use the spudger to lift the plastic keypad from the phone.
  9. Using a lens cloth, wipe away any build-up on or between the keys. Wait for the keypad to dry before reassembling.
    • Using a lens cloth, wipe away any build-up on or between the keys.
    • Wait for the keypad to dry before reassembling.
结论
Amy
于2012年10月15日注册
1 信誉积分
创作了4篇指南
团队
University of Maine, Team 1-4, Diaz Fall 2012 University of Maine, Team 1-4, Diaz Fall 2012 的会员
UMAINE-DIAZ-F12S1G4
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 205
