跳转到主内容
Motorola Slvr L7 Front Panel Replacement
你所需要的
  1. Motorola Slvr L7 Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,1
    • To ensure safety, discharge your phone battery below 25% before starting. A fully charged lithium-ion battery may cause a fire and/or explosion due to defects or damage.
    • Turn off your phone before beginning disassembly.
    • To replace the Front Panel, first begin by removing the battery.
    • Push down on the black tab located on the top center of the phone to access the battery.
  2. Motorola Slvr L7 Front Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it away from the back of the phone.
  3. Motorola Slvr L7 Front Panel Replacement: 步骤 3 中的图像 1,1
    • Using the T6 Torx Screwdriver, remove the four (4) T6 2mm Torx screws from the metal cover.
  4. Motorola Slvr L7 Front Panel Replacement: 步骤 4 中的图像 1,2 Motorola Slvr L7 Front Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the metal cover by inserting the flat end of the iFixit Opening Tool under the side of the cover, prying it away from the phone.
  5. Motorola Slvr L7 Front Panel Replacement: 步骤 5 中的图像 1,2 Motorola Slvr L7 Front Panel Replacement: 步骤 5 中的图像 2,2
    • Carefully disconnect the two connectors from their sockets located on the motherboard using the flat end of the iFixit Opening Tool.
  6. Motorola Slvr L7 Front Panel Replacement: 步骤 6 中的图像 1,1
    • Use the flat end of the iFixit Opening Tool to pry the antenna cable connectors from their sockets located on the motherboard.
    • Pull the antenna cable out to de-route it from the phone.
  7. Motorola Slvr L7 Front Panel Replacement: 步骤 7 中的图像 1,1
    • Use the iFixit Opening Tool to pry the black plastic screw cover away from the bottom of the phone.
    • Because the cover is attached with adhesive, moderate force is needed to remove the plastic screw cover from the phone.
  8. Motorola Slvr L7 Front Panel Replacement: 步骤 8 中的图像 1,2 Motorola Slvr L7 Front Panel Replacement: 步骤 8 中的图像 2,2
    • Remove the frame by inserting the flat end of the iFixit Opening Tool under the frame and prying it away from the phone.
    • Because the frame is attached with adhesive, moderate force is needed to remove the frame from the phone.
结论
2等其他人完成本指南。
Jorge Trujillo
于05/19/11注册
520 声望
创作了4篇指南
团队
CSU Los Angeles, Team 1-1, Nelson Spring 2011 CSU Los Angeles, Team 1-1, Nelson Spring 2011 的会员
CSULA-NELSON-S11S1G1
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,964
